wi-fi atheros
wi-fi atheros
народ помогите Не могу настроить ад-хос В режиме инфра всё работает но как только соединяюсь со 2м буком ХР вроде проходит конект значки мигают но через секунд 15 сбрасывает соединение Вторично не могу подклбчиться только через ребут.
сетевуха атерос убунта 8.10
- вывод iwconfig iwlist
- Screenshot.png (60.97 КБ) 11607 просмотров
Re: wi-fi atheros
dmesg?
Re: wi-fi atheros
leave писал(а):dmesg?
[ 15.469461] ndiswrapper: driver net5211 (,05/02/2007,5.3.0.45) loaded
[ 15.469844] ndiswrapper 0000:04:00.0: PCI INT A -> GSI 17 (level, low) -> IRQ 17
[ 15.469898] ndiswrapper (ZwClose:2198): closing handle 0xf6b40b28 not implemented
[ 15.470131] ndiswrapper 0000:04:00.0: setting latency timer to 64
[ 15.893107] ndiswrapper: using IRQ 17
[ 16.092862] HDA Intel 0000:00:1b.0: PCI INT A -> GSI 22 (level, low) -> IRQ 22
[ 16.092905] HDA Intel 0000:00:1b.0: setting latency timer to 64
[ 16.093828] wlan0: ethernet device 00:1d:d9:29:2b:9b using serialized NDIS driver: net5211, version: 0x50003, NDIS version: 0x501, vendor: 'NDIS Network Adapter', 168C:001C.5.conf
[ 16.098631] wlan0: encryption modes supported: WEP; TKIP with WPA, WPA2, WPA2PSK; AES/CCMP with WPA, WPA2, WPA2PSK
[ 16.127018] usbcore: registered new interface driver ndiswrapper
[ 16.142390] usbcore: registered new interface driver usbserial
[ 16.142412] usbserial: USB Serial support registered for generic
[ 16.142475] usbcore: registered new interface driver usbserial_generic
[ 16.142478] usbserial: USB Serial Driver core
[ 16.159048] Linux video capture interface: v2.00
[ 16.163056] hda_codec: Unknown model for ALC268, trying auto-probe from BIOS...
[ 16.188117] usbserial: USB Serial support registered for GSM modem (1-port)
[ 16.188476] option 6-1:1.0: GSM modem (1-port) converter detected
[ 16.188744] usb 6-1: GSM modem (1-port) converter now attached to ttyUSB0
[ 16.188763] option 6-1:1.1: GSM modem (1-port) converter detected
[ 16.188911] usb 6-1: GSM modem (1-port) converter now attached to ttyUSB1
[ 16.188938] usbcore: registered new interface driver option
[ 16.188942] option: USB Driver for GSM modems: v0.7.2
[ 16.217470] usb-storage: device scan complete
[ 16.236899] scsi 7:0:0:0: CD-ROM HUAWEI Mass Storage 2.31 PQ: 0 ANSI: 2
[ 16.254625] uvcvideo: Found UVC 1.00 device Acer CrystalEye webcam (064e:a101)
Re: wi-fi atheros
а что, родного драйвера нету?
что показывает dmesg |tail после отвала коннекта?
Re: wi-fi atheros
родной есть но он не работает приходится виндузовый использовать Ещё заметил винда принимает только 1 пакет и всё
сейчас вообще выдаёт wlan0 No scan results
Re: wi-fi atheros
ребут помог
[ 142.830505] type=1503 audit(1225731985.570:5): operation="inode_permission" requested_mask="r::" denied_mask="r::" fsuid=7 name="/proc/6039/net/" pid=6039 profile="/usr/sbin/cupsd"
[ 142.830578] type=1503 audit(1225731985.570:6): operation="socket_create" family="ax25" sock_type="dgram" protocol=0 pid=6039 profile="/usr/sbin/cupsd"
[ 142.830593] type=1503 audit(1225731985.570:7): operation="socket_create" family="netrom" sock_type="seqpacket" protocol=0 pid=6039 profile="/usr/sbin/cupsd"
[ 142.830608] type=1503 audit(1225731985.570:8): operation="socket_create" family="rose" sock_type="dgram" protocol=0 pid=6039 profile="/usr/sbin/cupsd"
[ 142.830623] type=1503 audit(1225731985.570:9): operation="socket_create" family="ipx" sock_type="dgram" protocol=0 pid=6039 profile="/usr/sbin/cupsd"
[ 142.830640] type=1503 audit(1225731985.570:10): operation="socket_create" family="appletalk" sock_type="dgram" protocol=0 pid=6039 profile="/usr/sbin/cupsd"
[ 142.830655] type=1503 audit(1225731985.570:11): operation="socket_create" family="econet" sock_type="dgram" protocol=0 pid=6039 profile="/usr/sbin/cupsd"
[ 142.830669] type=1503 audit(1225731985.570:12): operation="socket_create" family="ash" sock_type="dgram" protocol=0 pid=6039 profile="/usr/sbin/cupsd"
[ 142.830689] type=1503 audit(1225731985.570:13): operation="socket_create" family="x25" sock_type="seqpacket" protocol=0 pid=6039 profile="/usr/sbin/cupsd"
[ 142.830779] type=1503 audit(1225731985.570:14): operation="inode_permission" requested_mask="::r" denied_mask="::r" fsuid=7 name="/proc/6039/net/dev" pid=6039 profile="/usr/sbin/cupsd"
Re: wi-fi atheros
Выключи SeLinux для начала
setenforce 0 или правим конфиг
Re: wi-fi atheros
А что это и для чего?leave писал(а):Выключи SeLinux для начала
Re: wi-fi atheros
что - ответит википедия. для чего отключать - хотя бы для уменьшения загаженности логов. ну и смысла в использовании его на домашней машинке я не вижу вообще никакого.swea писал(а):А что это и для чего?leave писал(а):Выключи SeLinux для начала
